Diesel Forum - TheDieselStop.com - View Single Post - charging issue
Thread: charging issue
Old 10-24-2009, 10:34 PM   #21 (permalink)
Cjhstang
Cjhstang's Avatar
Originally Posted by Fordpowerstroke350 View Post
You can not immediately check a battery charge on shut down as you get what is referred to as a surface charge and not the true reading. If you turn on the lights for a moment sfter shutting down this will drain off the surface charge to give you a correct reading
hmm didn't know that... thanks!
well tested the truck as soon as i got home from work (roughly a 10min highway drive).
With lights on and radio on the volt meter said 12.7 staying somewhat constant. when i turned the fan on high she quickly began to drop in voltage, about .01 volt per every two seconds. when i turned all electronics off including lights i was up at 13.4.
like i said earlier i had napa test both batteries and alternator and they said they're all good.
this sound like its my voltage regulator? or maybe something else is draining the power somewhere?
thanks for the help so far all....
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline   Reply With Quote
