Diesel Forum - TheDieselStop.com - View Single Post - VP44 metering valve maybe?
Old 10-24-2009, 11:15 PM   #3 (permalink)
luckuslucas
luckuslucas's Avatar
Cycle the key on and off three times, leaving it in the run position on the third round. I'm pretty sure that on a '99 the odometer will display any codes stored. The odometer will say P ECU, ------, done, P PCU, ------, done. Give that a try and let us know what you find.
Do you have a way of reading the fuel pressure? If you don't have a gauge on there I would highly recommend getting one.
Air leaks? A small air leak somewhere in the system will make it hard to start.
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'96 International/Bluebird school bus, DT466, homemade WVO system, www.thebiggreenbus.org
'04 Jetta TDI, Greasecar WVO conversion (chases the bus around the country)
'89 MCI 102A3, Detroit 8V92TA, Frybrid/Rover Hybrids custom system
luckuslucas is offline   Reply With Quote
