Diesel Forum - TheDieselStop.com - View Single Post - 4x4 W.A.V.E build
Old 10-25-2009, 05:13 AM   #16 (permalink)
DisabledExplorers
Another cool feature I like is the massive under floor storage. This will be accessible for someone sitting on the gaucho (well maybe laying down to reach in) or from outside with the back doors open. I opted for the XL size space as a great use of where the factory spare was located. This will prove to be an excellent space for heavy recovery gear, spare parts and such.
Advance Adapters, the makers of the Atlas II Transfer case, offered not only their seriously tough case but also a remote shifter kit if we needed it. However there just aren't that many places to install the shift levers so instead Ebert the 4x4 guru there at SMB West moved the levers out from the seat a bit and then cut & threaded them. This will give anyone using the B&D power transfer base more room to rotate without hitting their feet on the shift levers.
DisabledExplorers is offline   Reply With Quote
