Diesel Forum - TheDieselStop.com - View Single Post - adding CAC to existing dt466 motor
Old 10-25-2009, 12:38 PM   #8 (permalink)
hemivolvo
hemivolvo's Avatar
Originally Posted by Evel486 View Post
The pyro (EGT) gauge is a good idea. Then turn up the fuel on your injector pump to get your boost but watch your egt gauge. The DT466 is a much stronger built engine than just about any automotive diesel out there so you shouldn't have to worry about head studs etc. Probably no need to go to bigger injectors yet either.
boy i love information, as first stated im a gas mechanic, this is my first deisel, i didnt know the inj pump is adj, i have a factory manual for the 466 and it does not go into tunning, ill do some research on the inj pump. thank s for advice ill get my egt hooked up and do some testing with the CAC and without its simple to un hook the cooler and go back stock.
it should also be simple to test for pressure drop of the cooler i dont think it is restricing my flow but ill check the cooler is 36in by 24in 2in thick with 30 or so flow tubes built by radiator specialtys in calif when i cut the tanks off for modification to fit the buss i was amazed how large the flow tubes were. i believe it was built for a big marathon provost bus as there factory is neerby and i got it from an auction handeling some of there stuff .
thank you both for the info
by the way what does HPOP stand for just curious
hemivolvo is offline   Reply With Quote
