Diesel Forum - TheDieselStop.com - View Single Post - charging issue
Thread: charging issue
Old 10-25-2009, 09:05 PM   #23 (permalink)
Cjhstang
Cjhstang's Avatar
Originally Posted by CGBear View Post
Do you have any aftermarket electrical goodies on the truck? I know I used to have a problem with a meyer snowplow setup with draining my batteries. It pulled power even when not at use. Had to install a switch to cut the power so I wouldn't have a dead truck in the morning.
hmm.... i do have an electric plow pump. i never had a problem like this before tho. That will be the next test...
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline   Reply With Quote
