"Wet" Shackle bolt problem
I have a 3axle fifth wheel that has the wet shackle bolts. I know the previous owner never lubed them. When i tried to, i could not get grease to about four of them. I am familiar with how zerk fittings work, unfortunately these are not removable.
I got the ball free on the zerks but they just won't take grease. Outside of removing the whole bolt, is there a trick to getting these to take grease? I tried jacking the axles up and down to relieve weight etc, but they won't budge. I even loosened the nuts, to no avail.
Jacking up the trailer to take all the weight off of the axles on a 40'er is something i don't have the tools to do at this time. I'd need several jackstands, the trailer has flipped axles and sits high, etc.
Sorry so long thanks for any help!
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
1988 Ford Thunderbird Turbocoupe 2.3
