Diesel Forum - TheDieselStop.com - View Single Post - 1990 F-600 Diesel Dump (Cummins/ Ford Venture)
Old 10-26-2009, 04:19 PM   #13 (permalink)
navistar45
nope, no glow plugs or intake heaters on the ford engines. never even seen block heaters on them down on my end of the country. to be honest the cummins engines in 2 tons down here rarely have intake heaters either. in your parts i would supect a block heater should be standard equipment, and could be easily added. split rims are a 2 piece design, there's a little ring that runs around the outer edge of the wheel, you will know em when you see em. be certain of the trucks capability, drive it a good bit before buying. sometimes it take several mile before a heating issue can show up. chking out that dump issue is a smart idea, could be just a cable , but make certain it isnt a pto or pump issue. be a good idea to see the cylinder, make sure it isnt bad scuffed or bent...
the fleet; ferds ,02'f350,01'f450.the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99' 3500hd with 12 valve cummins power. the goats, 90'd250, 91'd350 4x4, 05'3500. all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
navistar45 is offline   Reply With Quote
