Originally Posted by gager2002
My rear air vents ar blowing black exhaust soot everywhere? Anyone have an idea of what is going on? My headliner is turning black...
The rear system is totally a re-circulation system
Problem is not in your rear AC/Heat system you have exhaust coming in the rear doors or from under the truck.
A check for any exhaust leaks.
B check all door, glass and widow frame seals
Has the vehicle been in a wreak?
Factory exhaust or new system?
Also give us a clue as to your vehicle and equipment/mods.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished! (never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
