Originally Posted by bugman
If I remember correctly to pull the pan without pulling the engine you need to remove the cross member that is under the pan and is riveted in.
how did you get the rivets out? and what did you use to put it back?
1995 F350 7.3L Powerstroke 5spd 4wd CrewCab LongBed 230,000miles. -Skyjacker 6" lift -Sky Manufacturing shackle reversal -4" Flow Pro Exhaust (3.5" down pipe) -Tymar intake -Tony Wildman 4 position chip -DiPricol Optix EGT & Boost gauges with the A-Pillar gauge pod -Alpine CD, sony amp, Polk door speakers, and two 12"RockfordFosgate subs. -New Batteries -New Superduty STARTER -35” ProComp m/t. Brake controller. The clutch is a single mass Luk clutch
