Diesel Forum - TheDieselStop.com - View Single Post - sct for towing???
Old 10-26-2009, 08:41 PM   #13 (permalink)
psd_va
Originally Posted by teamroper60 View Post
Ummm, as others have stated, it can happen at stock power levels. It will happen if tuned and towing. The only question is how long will it take for this to happen. Believing otherwise is like sticking your head in the sand so you don't see your enemies. You don't have to believe me. Spend a little time and do a little research. You'll find tons of stories about towing tuned and blown gaskets. Most at weights far below the OP's or mine.
i hope you don't think i am trying to contridict you i'm not trying to be an a**. just stating a point that not every single 6.0 blows head gaskets. i have yet to blow mine at 119k. and i drive the s*** out it. if i was the OP i would call cale at BTS and talk to him over the phone and tell him your concerns and what you want to do. i have talked to him personally and his tunes are not hot enough that he says you need studs. even with his hot street tune. (or what ever it is called i forget)
psd_va is offline   Reply With Quote
