Like I said, Cary will do a better job explaining.
Two reasons the RSK / SD V Code set up is much better that just buying a lift kit:
With few exceptions lift kits are designed to reach a certain height and not sag. Ride quality is not first priority.
The OBS front suspension has tow design flaws that are corrected in the conversion....
The engineeers at Ford spent much more time on ride quality and longevity to design the taper leaf design. That is the leaves taper in thickness from center to end thus giving a true progressive spring rate.
OOPS, that's 3 already.
Diesel Mechanic 28 yrs
