Diesel Forum - TheDieselStop.com - View Single Post - IPR Signal question
Old 10-27-2009, 09:39 AM   #11 (permalink)
Tim the 2Lman
With the signal as I've described from the ECM/PCM, yes about 400psi. If I operate the IPR simulating 100% then I get over 3000psi. That's why i'm trying to figure out what the signal should look like. If the signal is normal, then I would have to conclude that the hpop is weak. If the signal is not right (i.e. maybe it should go between 0-12vdc instead of 6-12vdc) then I need to be looking elsewhere. The wiring under the hood and under the dash has had some butching done to it so I don't want to rush off and spend big $$ on hpop and that not be the problem. There is only about 100-150psi difference between having the ipr plugged in and not having it plugged in. Hope this helps. Thanks
Tim the 2Lman, '85 F350 2WD CC C6 basically stock 274K miles, '86 F350 reg cab flat-bed DRW 4-speed, '94 F350 powerstroke ZF-5 SRW long bed project soon to be daily driver, 217K miles.
Tim the 2Lman is offline   Reply With Quote
