Diesel Forum - TheDieselStop.com - View Single Post - Pulling Oil Pan
Thread: Pulling Oil Pan
Old 10-27-2009, 06:01 PM   #11 (permalink)
94strokerace
I wonder if one should tack weld the frame together before cutting loose the crossmember? Do you think anything would shift?
Another question, this two piece (described as mythical) oil pan deal, easy enough to see how it would go up....but how would you get the installed pan off?
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline   Reply With Quote
