Diesel Forum - TheDieselStop.com - View Single Post - 2005 6.0 Upgrades? mpg and horsepower?
Old 10-27-2009, 09:59 PM   #8 (permalink)
lubbockguy1979
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Originally Posted by alcook59 View Post
AFE makes some really nice intakes, anytime you open the exhaust you should open the intake IMO. Eric at innovative makes some good tunes from what I've experienced.
when the intake does not flow enough this is true. by removing the stock air intake and filter you are actually reducing the filtration. the advertised gains on most if not all aftermarket intakes is in the 3700rpm range. so you will get a boost in power there which is beyond what a stock truck is going to see typically. so to sum it up if you are looking for the asthetics of the a/m filter and want to reduce the amount of dirt that will be filtered get one. there is alot that could/can be done to further improve the stock intake with out reducing the filtration of the unit if you are seeking power. there is very little gain to be had for the $300+ price tag
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline   Reply With Quote
