Originally Posted by first_ford
using the upfitter switch is a nice idea, but I have a tendency to turn mine on when i remove a cup or something from the cup holders under the switches. Just throwing out an experience. It could cause a problem when hooked to a fuel pump.
FF, you bring up a great point. I talked with my dealer Bobby W. today. The truck is back. he said it is mounted in such a fashion that I know where it will be but it is outta sight. It has a timer on it for the 15 minutes. I just have to reach up under the dash and wind it up. I like the idea.
For me it takes the guesswork out of ...I better check and make sure I shut it off. Also added was a fuel gauge for the auxilliary tank which sits low in the center (I think). Bobby told me but until I see it I am not really sure. I dig that idea, knowing where that tank sits so I can estimate pretty close to how far I can realistically drive or when I should fill that tank up.
One thing for sure, with this set up, I do not have a reason to ever run out of fuel.. other than both gauges breaking which is highly unlikely
The Eclipse entertainment system should be mounted this week. Maybe Friday I could end up with a truck.. maybe Monday.. either way, it is getting close. and of course, I am getting excited.
