Diesel Forum - TheDieselStop.com - View Single Post - flywheel
Thread: flywheel
Old 10-28-2009, 09:00 AM   #7 (permalink)
LMJD
My Photos: (27)
Personally I've never heard of that being a chronic problem with any of the 855 cu.in. series through the years, maybe someone else has. The typical double disc pull clutch/flywheel assemblies are about all the same and trouble-free too. Unless he finds something obvious like overtorqued grade 5 (instead of grade 8) bolts, or whatever, that might be a tough one to figure out. Any outside drivers that might be putting it under a shock load at times? However in heavy trucks the weakest link is purposely designed to be the driveshaft because it does the least damage and is cheapest to fix. Under a severe enough shock load it will twist itself into a pretzel and break rather than something more spendy.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline   Reply With Quote
