Diesel Forum - TheDieselStop.com - View Single Post - bypass filtration
Old 10-28-2009, 03:53 PM   #7 (permalink)
snakyjake
Originally Posted by bigb View Post
Could you get the same benefit by running a bypass filter like the Fleetguard LF 9027? Is it two filters in one?
Fleetguard LF9027 (post; this may not be accurate):
Full Flow: 90% at 30 micron
Bypass : 50% of 10 micron
Amsoil:
Full Flow: 98.7% at 15 microns.
Bypass : 98.0% at 2 microns.
Not sure if the comparison is from the same test (single pass vs. multiple pass).
Not sure about capacity. When will Amsoil plug up from sludge/soot and reduce filtering at 2 microns?
It has also been said by Fleetguard that engine wear is between 2 and 22 microns.
Look at the prices. Amsoil is expensive. It might be worth changing filters and oil more often, than buying a single expensive one.
Jake
2000 F-250 7.3L Powerstroke. Build date 08/99.
snakyjake is offline   Reply With Quote
