Diesel Forum - TheDieselStop.com - View Single Post - eratic speedo
Thread: eratic speedo
Old 10-28-2009, 04:53 PM   #4 (permalink)
dikkstarr
dikkstarr's Avatar
Originally Posted by mansellp7 View Post
Mine will buck or jump like its trying to change gears or something. If I put the cruise control on the engine will sputter or jerk a little. It probably would act like its losing power , once it started doing it I just babied it home. I was scared of a large towing bill.
If the speedos off the tranny gets lost and doesnt know when to shift.
The only thing thats made mine stop or at least do it less, was to back in and out all ground wires bolts I could find, engine and inside cab. I also wiggled all the fuses and plugs around the fuse box area. It must be a bad connection somewhere.
I also put a new speed sensor in the diff, but that did nothing.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline   Reply With Quote
