Diesel Forum - TheDieselStop.com - View Single Post - Okay Boys This Girl Needs Help!
Old 10-28-2009, 05:36 PM   #6 (permalink)
6.0 tech
if you say its usually just a single drip it could be that they did not clean the engine off real good after the oil cooler was replaced. i would suggest putting some dye in it, cleaning it real good and running it about a hundred miles or so. then get under neath with a blacklight and see if it is new oil. if not clean it real good. i usually go through about 4 or 5 cans of brake cleaner when diagnosing leaks. you can see the dye with a regular light but a blacklight makes it show up better.
6.0 tech is offline   Reply With Quote
