First off when saying you want those kind of numbers out of a 7.3 just letting you know it wont be cheep and by all means is not a budget build lol AFE Stage 2 intake Larger 4 inch exaust MBRP Magnaflow take your pick guages boost, trans, piro, basics tuning get jody at DP-Tuner too set you up with one of his tunes make sure you tell him what your looking for out of your truck and what mods will be done, gunna need injectors Swamps or Beans Stage 3 260cc single shots or go with some Mini Me's. choose your "Big Oil" Dual HPOP set up. Termanator or Stealth are two big ones around here. next your turbos gotta be changed out and dont think a drop in replacement would be good enough such as the garret GT38R or somthing simple from Turbonetics, so your prob going to need a built H2e set up. if your looking for this to be a pull truck go with somthing smaller. while running the pressure through a new intercooler, could go with the 6.0 cooler somthing from spearco or i hate it but banks makes a nice one to.with that fuel and boost numbers head studds are going to be needed aswell ARP is popular. dont know your opinion on drugs but might want to throw some Water/Meth in there too keep things cool. or throw some nitrouse or propane at the motor. with numbers in the 500 area i think the internals should be good with the 01 as far as the rods being forged and all, pistons, heads and crank. (Could be wrong) id actualy like to know can someone answer that?. because you may need thigns along the lines of mahl coated pistons, fire ringed heads and a built and balence crank with all the trimmings. going to need a built transmisson BTS is recomended around here could go a bit pricy with suncoast just stay away from anything ATS. think iv got a lot coverd but id like to hear from the Big Horsepower guys out there id like to learn more as well good luck with your truck to guy
2000 White F250 PowerStroke 4X4 Off Road
6 Inch super Lift
38 Inch Nitto Muds
BushWacker Pocket Flares
Dick Cepek DC1's
AEM Bruteforce Intake
AutoMeter C2 Boost, Trans Temp, EGT
MBRP 4 Inch Turbo Back Up to 5 To 7 Inch GrandRock Miters
Edge Juice With Attitude Moniter(Just For Gauges)
Custom Programing From Jody DP-Tuner F5
Stock,No Start, High Idle, 80 Econ, 120 Race, 140 Agressiv
OverBoost Annihilator, HPX Cross Over Line IC Pipe Foil Delete MOD
Running Garret GTP38R Ball Bearin non WasteGated 1.15 Exhaust Housing
Transmisson Done by The Local Guy New Housing, Transfercase and Drive Line Factory 3.73's "All Heavy Duty Billet Steel Internals"
Pro Torq Stage Three Billet Torq Converter
Rhino Liner, 10,000K HID's, Black Diamond Eye Head Lights, Recon Running Board LED's, Remote Start, Dual 7 Inch Touch Screen In Dash DVD, 12 Inch JL Audio Sub, Rockford Fosgate 600 Amp
Still Get Smoked By 6.0's
But Whos Truck Do The Women Always Want to Ride in?
WyoTech 09
