Diesel Forum - TheDieselStop.com - View Single Post - 95' 7.5 problem
Thread: 95' 7.5 problem
Old 10-28-2009, 10:06 PM   #2 (permalink)
md18
You need to check the fuel pressure regulator if you have low fuel pressure on both tanks and your sure the pumps are running and the filter is clean. Also check the fuses, specifically the cigarette lighter fuse as that powers the obd2 port and will cause the scanner not to work.
2002 F350 CC SB Lariat 7.3 4x4 3.73 LS
Torredor Red, Viper 5701
md18 is offline   Reply With Quote
