Diesel Forum - TheDieselStop.com - View Single Post - Pulling Oil Pan
Thread: Pulling Oil Pan
Old 10-28-2009, 10:55 PM   #18 (permalink)
Garbage_Mechanic
I think the first set of photos shows it that way but then he welded it too. I'm pretty confident (30 years experience with big rig frame repair and yellow iron too) that it wouldn't work loose. I would use frame bolts which are grade 8 self locking with flanged heads on the bolt and nut. I will probably do it some time, if I need my pan off, or if I have the engine out. Really nice to be able to check bottom end or fix leak now and then.....
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline   Reply With Quote
