Originally Posted by boomboom
You are sooo right about (this is how they should have come) Did same thing 6 years ago. I only added 60k miles sense then but it still looks level. I'm not sure if they have sagged any but front wheel well sits 40" dead center of hub and rear is 41" with 285x75x16 . What is your ride height with virgin springs ?? NICE RIG"S and GREAT POST !!!
39.50 Front
40.50 Rear
with 265/75r16s
Going to try to squeeze some 285/75r17 Toyo MTs on some 17x8 ATX Mojave Teflons under it.
Originally Posted by caryt
Now you just need Bilsteins and a rear 30mm SD swaybar..along with modded b codes.
Those are on the to do list along with some new front bump stops.
For the bilsteins are these the part numbers I should go with:
Front F4-BE5-2818-HO
Rear F4-BE5-6209-HO
