Originally Posted by LoveTurbo
Always said you want somthing done right do it yourself! i hate going to the dealer or any shop in general and i work at one! Grab yourself a really nice and bright LED flashlight pop the hood and find it yourself start at the top look at all the oil lines make sure nuthings spotting you checked the oil filter? check it again then look up from the bellhousing to the top. if heavy on the ground you should get a good idea of where its coming from. on a 6.0 there is a litttle bit of room around the turbo back to the fire wall get back there look around. its gravity, oils going to leak down work in that direction. and if your running synthetic keep in mind that its thinnner and where basic oil would be fine, synthetic might find its way through some cracks or seals. it may be a newer truck but its still a 6.0. good luck
I tried that and I can't see anything, when I look under the truck it seems like it is leaking from the head on the drivers side, which is what they thought it was to begin with and then blamed the oil filter.
