Originally Posted by OT
DG....6L under warr. oil leaks are covered. I assume u paid PT $100.ded + cost of reflash? FMC says when diag. leaks..add dye/light test to help pinpoint leaks. Some obvious one's dont take dye test. Many place's can leak oil.
I dont understand...bandaid fix on CAC tube?...what problem did o/f cause?...turbo lag, how much lag? What was reflashing for? Way you explain o. leak...repairs done..ok for week. You drive it 15 min. oil leaking, wierd for sure. If oil actually dripping & like TR said..why not drive it right back to dealer? Yeah I know maybe cant etc etc, your choice. Are you ok with going back to same dealer?
It still is under full warranty I only have 30,000 miles on the truck. I had to pay because it was my fault, they said they had 4 hours in it but only charged me for 1 hour (cleaning) and the 85.00 for the reflash. They said they reflash would help with MPG and my turbo lag issue. The lag did not happend until they replaced the boots, it seems like it justs takes longer to get up to speed and I don't have the take off power I used to. Also the psi is running around 20 consistenly and it never used to do that. I will go back to the same dealer, maybe if I give them a BJ with will fix it right this time
