Most people that do this already have the wiring for the power adjustment. Since you have manual mirrors now you will need the adjusting switch/joystick for your door along with the new mirrors. If you can find the wiring from someone that will help, but I've never heard of anyone finding it that way.
Good Luck. You will enjoy the new mirrors, are you going with the new '09+ mirrors?
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
