Diesel Forum - TheDieselStop.com - View Single Post - Oil Cooler Failure
Old 10-29-2009, 05:16 PM   #5 (permalink)
6.0 tech
this job is a pain. they gotta replace all the hoses, the oil cooler, most shops will replace the egr cooler and send the radiator out to be cleaned. then you gotta run simple green through the cooling system to clean as much out as you can. then they'll run fords cooling system flush through it a couple times. you quote sounds actually pretty good seeing as this is a big job. but you said your 5 months till you go out of warranty and this should be covered.
6.0 tech is offline   Reply With Quote
