Diesel Forum - TheDieselStop.com - View Single Post - Fuel Injector Control Module (FICM)
Old 10-29-2009, 05:55 PM   #20 (permalink)
dikkstarr
dikkstarr's Avatar
Originally Posted by Strokin' 6.0 View Post
FWIW, and this is direct from my stealership, there are NO new FICMs, they are all reman'd units....some might just look newer than others.
International will not sell you a FICM, if they know you're buying it for a Ford...at least the International shop here in town won't.
Why such a swing in prices then? Mine cost me 1400, and the dealer said it was a new one, my invoice didnt say reman FICM. A reman is new internals with the old shell or casing, like trannies or alternators?
I wonder what part of it breaks and what they do to fix it? So it will just break the same way again in the future? Whatever goes bad inside them.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline   Reply With Quote
