Diesel Forum - TheDieselStop.com - View Single Post - Oil Cooler Failure
Old 10-29-2009, 05:58 PM   #6 (permalink)
newtodieseling
Originally Posted by 6.0 tech View Post
this job is a pain. they gotta replace all the hoses, the oil cooler, most shops will replace the egr cooler and send the radiator out to be cleaned. then you gotta run simple green through the cooling system to clean as much out as you can. then they'll run fords cooling system flush through it a couple times. you quote sounds actually pretty good seeing as this is a big job. but you said your 5 months till you go out of warranty and this should be covered.
Actually, I'm 5 months OUT of warranty. I could tell by the gunk in the degass bottle that it would take some time to clean this out of everything. They told me there is a kit, around 300 bucks that would permanently fix this issue whereas in the past they were fixing it and it would happen again. Considering how much I tow with this truck, and I'm ashamed to admit I was hauling 30,000lbs gross weight (truck, grain cart and oats) and regularly tow 14,000 lbs I can't complain about the truck. Sounds like I'm getting a fair price and that's all I can ask for.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
newtodieseling is offline   Reply With Quote
