Diesel Forum - TheDieselStop.com - View Single Post - considering wmo!!
Old 10-29-2009, 06:46 PM   #3 (permalink)
f350powerstroke01
ive researched wmo and im gonna build a filter set up but i still havent seen anything about mixing oils like atf and motor oil. ive seen ratios like 40% motor oil 10% atf and 50% diesel, but what if i had 10 gallons motor oil and 10 gallons atf would it be better to filter seperate or mixed? should i run the oil in truck and when empty run atf or safe to mix? what about waste oil and veggie oil is it safe to mix?
ERIC
97 F-250 Red ext.cab long bed 4X4 junky slush box e4od 4.10 gears no muffler, new power steering pump, vaccum pump, fuel pump,water pump, fuel heater un plugged, k&n air filter, waste oil powered free fuel nothing like stickin it to the man 217,000 still running strong
67 F-100 Ranger 351 W auto my first truck
93 mazda b2600i auto 143,000
wifes ride 98 lincoln navigator
used to own:
01 F350 psd crew cab 4X4 junky e4od
f350powerstroke01 is offline   Reply With Quote
