Diesel Forum - TheDieselStop.com - View Single Post - considering wmo!!
Old 10-29-2009, 07:51 PM   #4 (permalink)
ckanderson
ckanderson's Avatar
Originally Posted by f350powerstroke01 View Post
ive researched wmo and im gonna build a filter set up but i still havent seen anything about mixing oils like atf and motor oil. ive seen ratios like 40% motor oil 10% atf and 50% diesel, but what if i had 10 gallons motor oil and 10 gallons atf would it be better to filter seperate or mixed? should i run the oil in truck and when empty run atf or safe to mix? what about waste oil and veggie oil is it safe to mix?
i run a mix of both. probibly 90 percent oil, 10 percent atf and run it as a 50/50 mix in my truck. most of the oil i run is from hondas so its 5w-20
keep in mind im only on my first tank
it smokes just a very little bit at full throttle, but cutting my diesel costs in half is totally worth it.
2002 F-250 7.3 4x4
1964 Nova 400 w/350
ckanderson is offline   Reply With Quote
