Center dump exhaust manifolds for 6V92 Detroit
Anyone know where I might find a pair of center dumps with the T4 style flange or the like. In the interest of hood clearance I would like to replace the TV81 with two smaller turbos that equal the flow of the large frame TV81. Lot's of width but tight on height. The engine is an 1988 year model 6V92 TA @ 340 HP.
Anton
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp Detroit 6V92TA, Eaton 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
