Diesel Forum - TheDieselStop.com - View Single Post - Pulling Oil Pan
Thread: Pulling Oil Pan
Old 10-30-2009, 12:40 AM   #23 (permalink)
speeddemon31176
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
Stang65fst if you have the TTB suspension then yes the traction beams are connected to the crossmember in question however it is only two bolts to remove before removing the crossmember. If you were to cut the section of crossmember out and weld plates like I suggested and bolted it back together you would not have any issues like you may be suspecting.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline   Reply With Quote
