Diesel Forum - TheDieselStop.com - View Single Post - autometer guages not working
Old 10-30-2009, 05:51 PM   #8 (permalink)
boomboom
boomboom's Avatar
Originally Posted by runslikecrap View Post
yes they are lighting up like theyre supposed to but the needles dont move.
Ok lights are a differant power source then source to make gauges work. Red wire from gauges need keyed 12v source, White wire is your light source and black is of course ground. I would check for 12v on your red wire. If you had a bad ground your lights wouldn't work.
boomboom is offline   Reply With Quote
