I don't remember seeing a 'code-free' tune. Mine definitely isn't free from tripping the CEL that's for sure. Currently the way mine is tuned the HPOP can't keep up as I can only maintain about 1700psi under constant full throttle. Now, in Jody (et al)'s defense I've had my tune for a while and I'm sure there have been some improvements. I just look at it as a reason I need to get bigger oil
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
