6.0 transmission cooler installation pictures
I just finished the installation of a 26-row 6.0 liter PSD transmission cooler on my '02 F350.
While researching the topic, I found a general lack of pictures conerning the routing of pictures, so I thought that I would share mine.
During installation I installed a 3/8 hose Magnefine filter to the input line for the cooler to help it stay clean.
My initial installation used brass fittings from a hardware store that provided a 90* bend and a reduction in size from 1/2 inch hose to 3/8 inch. I had to use adapters to make it work. It leaked after the first install so I disassembled them to add some sealant tape. During disassembly I found the 3/8 hose barb was restricting the fluid flow inside the elbow by a considerable amount.
I decided not to run that combo and had a shop make some better lines for me with a smooth 90* bend that adapts the 1/2 inch hose to 3/8 inch.
Pics:
and new hoses:
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
