Diesel Forum - TheDieselStop.com - View Single Post - Left front suspension rattle....help me narrow it down....
Old 10-30-2009, 09:45 PM   #2 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
If you have a front sway bar with links going to the frame back near the rear of the front spring leaves, try unbolting the link on one side and taking it for a drive. If you can't duplicate the noise in that condition, then either the sway bar bushings on the axle are bad or the link bushings are bad.
Energy Suspension sells a replacement bushing kit for the whole thing for around $40. That would take care of you.
Hard or no-start? Check Here
