Diesel Forum - TheDieselStop.com - View Single Post - charging issue
Thread: charging issue
Old 10-30-2009, 10:25 PM   #27 (permalink)
Cjhstang
Cjhstang's Avatar
yeah already had that stuff tested and replaced volt regulator. still having problems.
any other thoughts? what would cause me to be running around 12.5 volts? I see the alternator has a ground prong to it...should that be grounded too??
also, what actually kicks the dummy battery light? mine won't go off even when i'm near 13 volts.
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline   Reply With Quote
