Originally Posted by 444-4D
What you may remember or may have heard isn't true.
It is true that their chips are for stock injectors.
I doubt anyones programming will make more power with stock injectors than Banks.
They just make the throttle more sensitive so you think you have more power.
I thought the 6 gun takes MAP sensor readings and messes with the ICP? I looked at the manual and that is all it can do.
And cannot be changed for anything else. Nor can it be custom tailored for anything else.
For the money he wants for his systems, it better. For that money, it doesn't even do anything for the transmission. For that, you'd have to buy another module. Can it make full use of a better turbo? Probably not.
Throttle sensitivity will not affect the dyno.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
