Diesel Forum - TheDieselStop.com - View Single Post - CPS removal
Thread: CPS removal
Old 10-31-2009, 04:17 PM   #1 (permalink)
StrokeIIAJ
CPS removal
Sorry for what is probably a dumb question, but how the heck do I get the CPS out? I guess I also need to find out if I have the right part. I am at the ~10 o-clock position next to the crank, right below the water pump. The 10mm bolt seems to be holding the timing marker on and I can not locate any other bolt. The connector is about 1/2 inch wide with rounded ends and 3 pins. Is this even the CPS?
I found another connector above the water pump with a singe pin connector, but again, I can not see it and I cant feel any bolt on it. Does anyone have a picture of the CPS so I can see what type of connector I am looking for and where the bolt may be located? Thanks for any help.
1994 F-350
StrokeIIAJ is offline   Reply With Quote
