Diesel Forum - TheDieselStop.com - View Single Post - change a gooseneck to a 5th wheel?
Old 10-31-2009, 07:33 PM   #6 (permalink)
js2941
js2941's Avatar
Originally Posted by SmokeyWren View Post
But instead of a sidewinder or manual sliding fifth-wheel hitch, I'd want to get the automatic PullRite SuperGlide hitch. Not cheap, but you're worth it. But you probably still can't fully jacknife the trailer. With a 14k or 18k hitch, the SuperGlide adds 14" to the hitch during a tight turn, which is even less than the SideWinder. But when I'm on the interstate, I want that kingpin over the axle, not 20" out behind the axle.
PullRite SuperGlide
I can vouch for that. I've been using mine behind a sleeper for years. Best hitch money I ever spent for my application. I use it with a TrailAire pin box extension as well. Can't see that in the pic. See my rig in my sig.
1994 F350 4dr SRW 2WD w/32" sleeper - 1 owner, ZF5, 410, Stock inj, SC1705 tuner, 3" BD dp, Isspro pyro & boost gauges, LUK flywheel & clutch, ebay clutch push rod mod, Kelderman air suspension(rear), converted YORK air compressor, DIY Ex Brake & AIC, 368k (on my way back to 300K!!! LOL)
js2941 is offline   Reply With Quote
