Diesel Forum - TheDieselStop.com - View Single Post - Center dump exhaust manifolds for 6V92 Detroit
Old 11-01-2009, 03:12 AM   #3 (permalink)
Huff
My Photos: (33)
Thank you, I took a look at some videos showing the 12v71 and 92s and I think that manifold will do, as long as they are installed with the outlet flange to the front.
Now I just have to find a pair.
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp Detroit 6V92TA, Eaton 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
Huff is offline   Reply With Quote
