Originally Posted by stang65fst
Runs great when it starts. Everything is just as it should be good throttle response. Doesn't smoke a start up. Goes down the road like a raped ape.
I just put in new stage 1 injectors in my truck and I have the exact same issue... It's not the glow plugs... I have no white smoke on start up or anything. I have to crank my motor over for about 10 seconds for it to finally start, but once it starts it runs great! If I shut it off and then restart it right after, I have the same long start problem. Is it possible that the high pressure oil resevour is draing down that fast?? I dont see how that is possible. Before the new injectors, my truck use to start in about 2 seconds... Not sure what to check to fix this problem.
