Diesel Forum - TheDieselStop.com - View Single Post - vibration when braking
Old 11-01-2009, 11:52 AM   #2 (permalink)
stevedunham
stevedunham's Avatar
My Photos: (6)
Most common cause on these trucks is warped front rotors. It's also possible that your trac bar has come loose but that usually manifests itself as a vibration when you take off, not when you hit the brakes. I had warped front rotors this past summer and they got real bad when descending mountain passes and hitting the brakes. It got pretty scary at times so I decided to upgrade. After researching here and a few other places, I ended up with PowerSlot Cryo rotors ( all 4 corners) and HAWK LTS pads and I did the install DIY style... Every chance I get (and I've had many opportunities with this truck) to replace or upgrade the stock running gear, I jump on it. So far, very, very happy with the Powerslot/HAWK combo... Much better performance than stock, dust is pretty much non-existant, no brake fade, strong on downhill panic stops, no squeaks... Well worth the $$$...
** SMD '04 F250 SD King Ranch delivered 8/19/04 **
28% Tint, Leer 100XL Cap, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, MBRP Duals, 4.56's w/ F&R ARB's, original motor blown @ 31,000..! Dynatrac Dana 60 35 spline stubs kit, PIAA 520 ATPs, Xenon HID's, Powerslot Cryos/Hawk LTS, SCT X3, blown Turbo replaced with II 60FORDHY, 58V FICM PICS
stevedunham is offline   Reply With Quote
