Diesel Forum - TheDieselStop.com - View Single Post - 6.4 High Idle Wiring
Old 11-01-2009, 01:48 PM   #28 (permalink)
dc4
Hi all, new to this forum found it on the powerstroke forum. Anyways I did this mod without the upfitter switches, I had to use the purple wire(ignition hot-in run) and and the yellow/green seic wire run to a switch for my high idle. I looked for those upfitter wires forever till I called ford and realized that since I didnt have the upfitter switches i didnt have the wires. Anyways i wanted to ask you guys something about what the guy at the ford body builder service dept told me, which was in order to prevent diesel coking and wet stacking you needed to get your idle up to 1300 rpm. I guess in order to do this you need a potentiometer. Anyone know where to get a potentiometer for an auto, I have found several on the net but the were for other applications and wouldnt work. Thanks for any help
Ford F-250 XL 6.4L Reg Cab
dc4 is offline   Reply With Quote
