Originally Posted by Strokin' 6.0
Roper,
It would seem to me that the exhaust cooler inlet gas pressure would equalize, if the EGR were shut permanently, so you would never have to worry about the cooler bursting.
You may well be right about the pressure equalizing but I wasn't talking about constantly increasing pressure. Even if it equalizes, it will do so at some pressure level... What I am getting at is the constant pressure, combined with heat stress over an extended time.. With
most of the factory flashes, the EGR valve is open to some extent while doing anything other than idle or WOT. When the valve is open, there would be minimal pressure since it has an escape point to move the gases through it. Keeping that valve closed constantly will keep a certain pressure on it all the time.. At least, that was my theory, which may be completely wrong........
Toreador Red/
Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
pics
#43
SLAPS President and Webmaster
