Diesel Forum - TheDieselStop.com - View Single Post - 2004 6.0 question
Old 11-01-2009, 06:16 PM   #7 (permalink)
teamroper60
teamroper60's Avatar
Originally Posted by Strokin' 6.0 View Post
According to my indy mech, that is a good thing...in case any water whatsoever were to get into the fuel and past the separator, the injectors are able to "spit" everything out.
What?????????????????
Since the engine is not running when this is happening, there is no high pressure oil. Without high pressure oil, nothing gets injected, so nothing could get "spit out"....
Originally Posted by Jared583 View Post
so there's nothing wrong with it? i've never heard a 6.0 do that before
The flash that shakes the spool valves was only used for a short period of time. That's probably why you haven't heard it before. There is nothing wrong with the flash or what it does. But folks complained about the noise. Ford then brought out the "inductive heating" flash to heat the spool valves instead of shaking them. Both flashes were created to deal with rough running on cold starts.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline   Reply With Quote
