Diesel Forum - TheDieselStop.com - View Single Post - fuel leak
Thread: fuel leak
Old 11-01-2009, 07:00 PM   #7 (permalink)
midwestconnection
midwestconnection's Avatar
Originally Posted by clev View Post
Thanks, rpm; I'm printing the instructions as I type. I have to use this van all this week and will not have time to do this job. If I plug the tube to stop the seep will that cause any problems? It's not leaking very much, but I'm concerned about a fire.
They call it the valley, the area in between the two cylinder heads on a V8. It has holes in the back that drain leaks rather than filling up.
There should be no fire danger unless you plug these up.
The fuel filter is really hard to get at unless you have a good shop and lights and the know how.
You will probably have to remove the blower to get at it. No fun if you haven't done it before.
Not to bad if your a good mechanic.
midwestconnection is offline   Reply With Quote
