Diesel Forum - TheDieselStop.com - View Single Post - Camper control problems
Old 11-01-2009, 07:06 PM   #1 (permalink)
jstwhln
jstwhln's Avatar
I've got a 99 F350 SRW 4WD that I use to haul my truck camper, an Arctic Fox A990 (~3100 lbs wet).
In an attempt to better control the load, I installed air bags with valves to isolate them from each other. It helped a little, but I'm not sure if there is more that can be done.
Are there any big differences between the stock sway bars (F/R) and ones available from aftermarket manufacturers like Hellwig?
Also, the bracket that mounts the front stock sway bar on the passenger side is considerably less stout than the driver side. Is there any way to upgrade/retrofit a better passenger side bracket?
Late '99 F350 4WD CC LB
  • Banks Power Pack
  • Banks Brake
  • Banks Billet T/C
  • Tru-cool Max 45000 BTU trans cooler + V-10 cooler
  • HPOP rail x-over
  • 203°F thermostat
  • FS-2500 bypass filter
  • Warn premium manual hubs
  • Amsoil synthetic fluids
  • S&B intake
  • Bilstein shocks
  • 4" KC driving lights.
"Freedom is not free, but the U.S. Marine Corps will pay most of your share." Captain J.E. "Ned" Dolan, USMC
jstwhln is offline   Reply With Quote
