08 F450 Transfer Case Broke????? Help!!
ok, i have an 08 F450 with 111,000 Miles on it.. the truck is used for transporting and hauling cars... well today on the way home with an empty single car trailer i was driving and i felt the truck start to shake, so i pulled over and took a look underneath of it and i saw a puddle of trans fluid, so i figured it was the transmission. i went to start the truck to check for further damage the truck started fine, no warning lights or nothing?? i then put the truck in every gear and it did nothing and i heard i slight grinding noise like it had no gears, later on the tow truck came and picked the truck up, and when he did, we noticed the transfer case was cracked??? and that is what the problem was.. how would this happen??? we can not figure it out? nothing was run over or hit?? any ideas would help thanks!!!
